May 3, 2020 at 10:18 am
Sherif
SubscriberHi,
I did 2D simulation on Ansys Fluent. iterating was very smooth and one iteration takes ~1sec as the mesh has 80 thousands elements.
I did the same model but 3D I got 6 Million elements and one iteration takes ~15 minutes. is that normal ?
I have Intel Core i5 with 8 Gb Ram. Using parallel processing with 4 cores and single precision instead.
The model is a simple supersonic flow over rocket nozzle.
Any ideas? Is that normal? -
May 4, 2020 at 1:07 pm
Kalyan Goparaju
Ansys EmployeeHello,Â
1 iteration for 15 minutes sounds too slow. Can you try a couple less denser meshes (3mil and 1 mil perhaps) and see if the time per iteration reduces?Â
Thanks,Â
Kalyan
May 4, 2020 at 1:44 pm
DrAmine
Ansys EmployeeDepends on which resources are you running but very slow.
- The topic ‘Fluent Iteration Too SLow’ is closed to new replies.
1306
