October 30, 2021 at 1:46 am
robR_CFD
SubscriberHi Fluent Friends,
Does anyone know of a tutorial, example or youtube vid of using the fault tolerant workflow for external aero?
Ive seen the worked example of the manifold for internal flow, but would like to see an example where the advanced feature sets are used for boi's and edge detection.
Thanks
November 1, 2021 at 12:27 pmKarthik Remella
AdministratorHello As far as publicly available resources on this topic, we have a detailed tutorial on the exhaust manifold, which you seem to have already looked at. There is also another video - external flow over a cyclist.
Fluent's Task-Based Fault-Tolerant Workflow Speeds Meshing Dirty Geometry - YouTube
Besides this, there is a separate course on the Ansys Learning Hub (ALH) that includes several other tutorials. You will need the ALH subscription for this.
Karthik
Viewing 1 reply thread- The topic ‘Fluent Fault Tolerant Meshing Workflow – external aero’ is closed to new replies.
4633
1540
1386
1225
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
