September 12, 2020 at 9:11 pm
heisenmech
SubscriberHello everyone,
I've been recently struggling with Fluent's high memory usage when running on my workstation which has 16 physical cores -and Xeon (R) CPU @2.30 GHz with 96 GB RAM. I had been using Fluent 2020 R1 without any issue until recently I noticed that the PC became extremely slow.
When I checked the task manager, I noticed that Fluent was using 99% of the memory with not very high CPU usage, which is strange because it should normally use most of the CPU. I used to launch Fluent with 28 solver processes with very similar cases, CPU usage were high and RAM usage was roughly around 70%.
I tried running with less processes, but no luck unfortunately.
Even when I stop the solver from iterating but keep the session open, RAM usage is still about 85%.
Please the screenshots attached.
Anyone else experiencing such issue? or what potentially is going wrong?
Many thanks,
Oguzhan
September 13, 2020 at 11:04 pmKarthik Remella
AdministratorHello,nWhat type of simulation are you running? Also, what is your overall mesh count? It is possible that the RAM is high because of your overall mesh count.nKarthiknnSeptember 14, 2020 at 7:15 amheisenmech
SubscriberHello Karthik,nIt's an LES with around 27 million nodes -structured hexa. I remember running a simulation with very similar case but had no problem with RAM. As I mentioned CPU usage was high but RAM usage was pretty moderate. nWhat I have also noticed is that if you look at the first screenshot, CPU is not distributed equally between fi_mpi which I think is a bit strange,too.nThanks.nSeptember 14, 2020 at 12:57 pmRob
Forum ModeratorAre you running either the Pressure Based Coupled or Density based solver? Do you have any dynamic adaption?nSeptember 14, 2020 at 3:10 pmheisenmech
SubscriberHi Rob,nIt's pressure based. Yes, I am running with Dynamic Stress. That's actually a good point. Maybe, that's why it constantly uses huge amount of RAM.nSeptember 14, 2020 at 3:51 pmRob
Forum ModeratorIf you're running adaption check the cell count: you may have more cells than you think. Also look into load balancing as you'll have loaded some cores more than others. nSeptember 14, 2020 at 9:01 pmheisenmech
SubscriberSorry, I think I misinterpreted your comment on dynamic adaption. There is no dynamic mesh adaption in my case. I just checked the partitioning and load balancing tab where dynamic mesh is grayed out. The only option available there is Mesh Adaption which is set to 5 by default.nI also double-checked the total cell count which matches perfectly with ICEM.nnSome other subsections under Partitioning and Balancing as follows;nnOptions --> No of Partition = 16 (16 cores are being used at the moment) , n --> Reporting verbosity = 1, Reordering Methods = Architecture AwarenOptimization --> Smooth = 3nWeighting --> Faces per Cell - User Specified = 2 Additional Cell WeightnDynamic Load Balancing --> Mesh Adaption = 5nnViewing 6 reply threads- The topic ‘FLUENT EXCESSIVE MEMORY USAGE’ is closed to new replies.
6625
1311
