September 18, 2023 at 4:21 am
Jacob Ellis
SubscriberI read that making sure processor affinity is set is helpful for speedup. But it seems random (with the same number of processors) when I am able to see the message of sucessful processor affinity set. Is there anything I can do? I already close out all unwanted programs and use less than the total physical cores on my machine (FLUENT 2023R2, Windows OS, Intel i9-12900k, 64GB RAM).
September 18, 2023 at 7:16 am
Aras karimi
SubscriberHello
I also have your exact operating system, however, when I compare it with a system with CPU i7 4770K (4 cores), its speed is not very high and there is a slight difference.
Do you also have this problem?
Do I have to do anything special?When I open Fluent, I get this message in the Fluent console. Do you also receive this message?
Note: Rank = 0: Process affinity not being set (6).
Note: Rank = 1: Process affinity not being set (6).
Note: Rank = 2: Process affinity not being set (6).
Note: Rank = 3: Process affinity not being set (6).
Note: Rank = 4: Process affinity not being set (6).
Note: Rank = 5: Process affinity not being set (6).
Note: Rank = 6: Process affinity not being set (6).
Note: Rank = 7: Process affinity not being set (6).
Note: Rank = 8: Process affinity not being set (6).
Note: Rank = 9: Process affinity not being set (6).
Note: Rank = 10: Process affinity not being set (6).
Note: Rank = 11: Process affinity not being set (6).
Note: Rank = 12: Process affinity not being set (6).
Note: Rank = 13: Process affinity not being set (6).
Note: Rank = 14: Process affinity not being set (6).
Note: Rank = 15: Process affinity not being set (6). -
September 18, 2023 at 1:25 pm
Jacob Ellis
SubscriberÂ
Yes. That is the reason for my question. I get the same behavior and am wondering how to get the process affinity to set.Â
September 18, 2023 at 3:01 pm
Aras karimi
SubscriberWhat is the meaning of this message? I don't get it.
Is your Run Fluent speed low?
- The topic ‘[FLUENT] Ensuring Processor Affinity is Set’ is closed to new replies.
