January 30, 2021 at 10:59 pm
MatiasB26
SubscriberFebruary 1, 2021 at 4:19 pmRob
Forum ModeratorHave a look at mesh interfaces: those are the walls created to account for when the two faces don't exactly match. Given it's a radiation model and therefore the surfaces between the fluid and solid are important I'd suggest not using them and going back to the geometry too to make sure you create a conformal mesh. nFebruary 1, 2021 at 4:21 pmRob
Forum ModeratorThat might explain the problem you see here /forum/discussion/23943/fluent-crashes-as-is-writing-the-view-factor-filenViewing 2 reply threads- The topic ‘Fluent creates empty surfaces when the mesh is translated.’ is closed to new replies.
2918
970
852
599
591
