TAGGED: fluent, gaussian-heat-source, moving-heat-source, udf
November 10, 2020 at 12:23 pm
Myslings
SubscriberI am trying to make an UDF for additive manufacturing (material deposition on a flat plate) where there is moving heat source on the substrate and mass source added to the melt pool. For this I need to locate the interfacial cells using this command if(C_VOF(cell,sec_th)>0.05 && C_VOF(cell,sec_th)<1). This command works well for the energy source term. However, if I use the same command for the mass source term fluent crashes with 999999: mpt_accept: error: (Node 0: Process xxxx: Received signal SIGSEGV). Can anyone kindly help me solve this issue? -
November 10, 2020 at 2:01 pm
Forum ModeratorCan you run one time step without the UDF and then switch it on? SIGSEV can occur some data isn't present for the UDF and that causes a failure. n -
November 11, 2020 at 1:07 am
Myslings
SubscriberThank you for your response. I ran 5 time steps without UDF and then I turned on the UDF. Same error occurs. Any other ideas on how to solve this?n -
November 11, 2020 at 11:23 am
Forum ModeratorHaving had a more careful look I'd suggest not re-using variables. It probably shouldn't matter but it's something I always avoid doing. What happens if you use a fixed mass source rather than the varying one? n -
November 11, 2020 at 11:43 am
Myslings
SubscriberEven I thought about it and changed the variable names and I also tried constant mass source. Nothing seems to work. If I remove the C_VOF command line if(C_VOF(cell,sec_th)>0.05 && C_VOF(cell,sec_th)<1) then the code works. But I need the C_VOF condition to locate the interfacial cells and apply the mass source on those cells. n -
November 11, 2020 at 3:12 pm
Forum ModeratorIf you want the interface cells surely 0.45 < Vol fraction < 0.55 give or take? In your case you'll be adding mass of whichever phase to the region where it's all/mostly one phase. n -
November 12, 2020 at 3:38 am
Myslings
SubscriberI tried several different volume fraction limits but fluent still crashes. I have two cell zones, substrate cell zone above which there is air cell zone. Phase 1 is air and phase 2 is substrate material. I apply the mass source term in phase 2 of the substrate cell zone. I think the C_VOF function is causing some problem when added to the continuity equation. I'm not sure what the problem is. n -
November 12, 2020 at 10:52 am
Forum ModeratorIf you check the rates how much mass are you adding to the substrate fluid? n -
November 12, 2020 at 12:22 pm
Myslings
SubscriberI'm trying to use the equation in the attached figure to calculate the mass source. F_powder is 0.28 g/s and eta_powder is 0.6. Actually, when I apply the mass source term by giving x,y,z position (to check), it is working. But when I try to apply on the interfacial cells using x,y and C_VOF(cell,sec_th)>0.05 && C_VOF(cell,sec_th)<1, then fluent is crashing. I don't know why particularly this condition is making this error. n
n
November 12, 2020 at 1:03 pm
Amine Ben Hadj Ali
Ansys EmployeeAre you using the VOF model? n -
November 12, 2020 at 1:04 pm
Myslings
SubscriberYes. I am using the VOF model.n -
November 12, 2020 at 1:17 pm
Amine Ben Hadj Ali
Ansys EmployeeWhich UDF source is causing the crash?n -
November 12, 2020 at 1:18 pm
Myslings
SubscriberThe second one. Mass sourcen -
November 12, 2020 at 1:39 pm
Amine Ben Hadj Ali
Ansys EmployeeBecause it is wrong if you are hooking it into the VOF equation. n -
November 12, 2020 at 1:52 pm
Myslings
SubscriberThen how should I do it? Since I am adding the mass source to the particular phase in cell zone should I just use C_VOF(cell,thread>0.05 && C_VOF(cell,thread)<1? And not specify primary and secondary threads?n -
November 12, 2020 at 2:19 pm
Amine Ben Hadj Ali
Ansys EmployeeYes because the thread passed is already the phase thread!n -
November 13, 2020 at 12:26 am
Myslings
SubscriberThanks a lot. Now the error is gone after I changed it to C_VOF(cell,thread>0.05 && C_VOF(cell,thread)<1 without specifying phase specific threads. Should I use the same method for energy and momentum source terms too? n -
November 13, 2020 at 2:59 pm
Amine Ben Hadj Ali
Ansys EmployeeYou first need to understand the conservation equations solved when using VOF model.nnNo not required as single momentum and single energy are solved.n -
November 15, 2020 at 8:36 am
Myslings
SubscriberOk. Thanks a lot for your help.n
Viewing 18 reply threads
- The topic ‘Fluent crashes with 999999: mpt_accept: error: when using C_VOF command in UDF’ is closed to new replies.
1500
1386
1209
