Fluent crash in Ansys Workbench
    • ghislain_madiot
      I am experiencing difficulties with the workbench interface. I have constructed a workflow using design modeler, mesh, and Fluent. Within this workflow, I have a specific set of geometric parameters that I wish to test. However, each time I attempt to update these parameters, Fluent crashes and I encounter the error message "Ansys.Fluent.CortexNotAvailableException". Consequently, I am compelled to uninstall Fluent and then reinstall it to regain functionality.
      Can you please provide some insights into what might be causing these issues?
      Ghislain
    • Nilay Pedram
      Thank you for reaching out to the Ansys Learning Forum.
      You can follow these threads for better understanding of the problem.
      Ansys.Fluent.Cortex.CortexNotAvailableException error
      Error: Exception of type ‘Ansys.Fluent.Cortex.Cortex not availableException’ was thrown
      For more information, please refer to Fluent User's Guide - 40.1. Introduction to Parallel Processing (ansys.com)
      If you are not able to access the above link, please follow this forum discussion - How to access the ANSYS Online Help
      Hope this helps you. Thank you!
  • The topic ‘Fluent crash in Ansys Workbench’ is closed to new replies.
