FLUENT cannot calculate volume of “Custom Field Functions”?
    • Jiangtao Lu
      Bbp_participant
      I defined a parameter using “Custom Field Functions”, and then a range of this parameter using ”Cell Registers”. The target is to calculate the liquid volume of this parameter with the specified range.
      I first tried “Volume Integrals” of the “Cell Registers”, Fluent got frozen.
      I then tried “Named Expressions” using first Flag = IF(cell_register_0,1,0), then VolumeInt(Flag,['domain']), Fluent still went frozen when compute.
      I know “Mesh Separation” will work, but I need to calculate multiple ranges for a plot (x axis: parameter, y axis: volume percentage). So it is not an option for me.
      Any solution to this problem? Thanks.
      Channel Partner
      Have a look at this   https://innovation.ansys.com/base/articles/topic/is-there-a-way-to-get-the-volume-of-a-register-using-expression-prem
      Otherwise you can patch a User Defined Scalar (UDS) to be 1 in the register and then report the sum of cell volume x UDM.
    • Jiangtao Lu
      Bbp_participant
      thanks Rob, but it seems i have no access to the link. Could you please past it here? Thanks.
      Channel Partner
      I can't, if it's not visible it's registered user's only so I can't share - I can't tell from this side as I have staff access.
      Try searching in Answers or search tool on the front page incase I've accidentally got to an internal version.
