September 18, 2020 at 4:08 pm
pradeep632
SubscriberHello could anyone tell me what command to use in the journal file to export solution data in tecplot format in fluent . I am trying to run a transient case in batch mode using the journal file. I am trying to save my solution data every 100 time steps. I am running a total of 1 million time steps. I know the auto-save data frequency saves dat files but I need to export data in tecplot format. Any help with the journal file would be highly appreciated. Thank you. n -
September 18, 2020 at 4:53 pm
September 20, 2020 at 11:44 pm
pradeep632
SubscriberThank you very much. However I only want to save velocity data in tecplot. With the command you mentioned, fluent includes other variables like pressure, density. Can I write a command to save only the velocity files. Thank you.n -
September 21, 2020 at 1:34 am
Karthik Remella
AdministratorPlease check which variables are selected under 'File -> Export -> Solution Data' . Change 'File Type' to 'Tecplot' and see what variables are selected.nAlso, is Velocity not being written (along with pressure, density, and others) at this point?nThanks.nKarthikn
- The topic ‘Fluent batch mode’ is closed to new replies.
