July 26, 2024 at 5:23 pm
komal.gada
SubscriberHi,
I have a university cluster based on RHEL. I recently got Ansys 2023 R2 installed. While running fluent in batch mode, I cannot read any case/data file. I get the following error:Â Â
> file/read-case
case file name [".cas"] /home/012542567/FreeJet_Baseline_LES.casError: File "/home/012542567/FreeJet_Baseline_LES.cas" not found!
Error Object: #fI tried using a journal file but still have the same issue. I am not able to read any case/data on the cluster. Any help is appreciated.Â
- Komal -
July 29, 2024 at 12:57 pm
Prashanth
Ansys EmployeeHi,
Use ls command to confirm if the files are in the Fluent directory. If not, place it there and then read it again.
- The topic ‘Fluent 2023 R2 unable to read case/data file while running in batch mode on HPC’ is closed to new replies.
