November 23, 2021 at 5:44 pm
BjornKierulf
SubscriberI am trying to run cases in Fluent on a remote linux server via GUI. When fluent loads it gives the following message in the text interface:
Host spawning Node 0 on machine "d0147" (unix).
/shared/centos7/ansys/2021-R1/ansys_inc/v211/fluent/fluent21.1.0/bin/fluent -r21.1.0 3ddp -flux -node -alnamd64 -t32 -pinfiniband -mpi=intel -ssh -mport 10.99.101.147:10.99.101.147:43661:0
Intel MPI 2018 may not work due to DAPL deprecation in Mellanox OFED 5.1
 * Use -pib.ofed in such case.
Has anyone encountered this error before, or does anyone know what could be causing this? Additionally, does anyone know how or where I would specify the -pib.ofed tag? Since I am using a GUI I don't type the command to launch Fluent.
Thanks,
Bjorn Kierulf
November 29, 2021 at 2:50 pmHunter Wang
Ansys EmployeeCheck latency and bandwidth in Fluent GUI > Parallel, if latency values are lower than 3 and bandwidth values are higher than 3GB, IB with DAPL should still work.
To force to used OFED (ofa farbrics for Intel MPI 2018), try to add -pib.ofed when launching Fluent launcher, also add -mpiopt="-genv I_MPI_DEBUG=2" as below to print Intel MPI debug info.
/shared/centos7/ansys/2021-R1/ansys_inc/v211/fluent/bin/fluent -pib.ofed -mpiopt="-genv I_MPI_DEBUG 2"
in Fluent launcher GUI > Parallel Settings > Interconnects, it should show ib.ofed, also in Fluent Console (after it's launched), it should print Intel MPI fabrics info:
MPI startup(): shm and ofa data transfer modes
April 9, 2023 at 6:10 amkevin1986
Subscriber> bandwidth values are higher than 3GB
In windows, I found 2021/2022/2023 bandwidth is much slower than 3GB. Please check the details here: /forum/forums/topic/new-version-fluent-is-slower-than-2020r2/
We were stuck here for more than a year. We dont know why..
May 15, 2023 at 7:11 amcoalition strengthen
SubscriberIB with DAPL should continue to function if the latency value is less than 3 and the bandwidth value is more than 3GB. To output Intel MPI debug data, use the -mpiopt="-genv I_MPI_DEBUG=2" and -pib.ofed options with the Fluent launcher to force the usage of OFED (ofa farbrics for Intel MPI 2018).
Viewing 3 reply threads- The topic ‘Fluent 2021 R1 running on a linux server has issues with Intel MPI 2018’ is closed to new replies.
4597
1495
1386
1209
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
