January 20, 2024 at 3:38 am
Rui Qiao
SubscriberRocky's SPH+DEM combination seems to be a powerful tool for fluid-structure interactions. Can it be used to solve the following problem?
A thin layer of liquid sits on a rigid substrate, with one of its faces exposed to air. A brittle sphere impacts the substrate. As the sphere moves, it may touch the substrate and fracture while interacting with the liquid. Can Rocky's SPH+DEM coupling handle such a problem? The flow of air is unimportant, and the flow of liquid may be considered incompressible.
Thank you very much!
February 2, 2024 at 4:55 pm
Lucas Bertollo Baggio
Ansys EmployeeHello Rui,
this scenario can be simulated by SPH-DEM in Ansys Rocky with breakage enabled. You can check on Rocky Tutorial 25 to learn more about SPH-DEM setup, and on Rocky User Manual to get insights about particle breakage.Â
Feel free to reach out and continue asking your questions here.Â
Best regards,
Lucas
February 2, 2024 at 10:08 pm
Rui Qiao
SubscriberThanks! We will give it a try.
- The topic ‘flow+fracturing simulations’ is closed to new replies.
