February 7, 2019 at 4:31 am
ashiadarsh
SubscriberHi All,
I am simulating the flow of water in a square channel...at the outlet boundary condition is Pressure outlet with Gauge pressure zero...at the inlet mass flow rate is specified...what is the value of Initial/Supersonic gauge pressure i should specify at the inlet?
Adarsh
February 7, 2019 at 9:26 am
Keyur Kanade
Ansys Employeeif your flow is going to be supersonic then this value will be considered. if your flow is not supersonic, you can keep it as default i.e. zero.
February 7, 2019 at 9:33 am
ashiadarsh
SubscriberOk Thank you for the reply...so what will be the case for a supersonic flow?..i wanted to simulate the flow through nozzle also with Air as the fluid
Adarsh
February 8, 2019 at 4:33 pm
Forum ModeratorFor supersonic flow you'll need to set the initial pressure too: if you click on "Help" in the boundary condition panel it'll take you to the correct page and then read & follow the links.
- The topic ‘Flow Simulation’ is closed to new replies.
6304
