August 16, 2024 at 4:02 am
ARF.Z13
SubscriberHi,
I want to simulate the flow film thickness over a vertical wire mesh screen. I used the VOF method and defined a stationary fluid domain, with the screen mesh wall having a translational velocity in the y-direction. Unfortunately, I cannot capture the fluid behavior between the holes.I believe the problem might stem from the moving wall condition. In ANSYS Fluent, wall motion relative to the adjacent cell zone that is normal to the wall cannot be properly captured.
I am unsure how to resolve this issue to make the simulation more realistic, specifically to see the flow stick between the openings due to capillary forces and surface tension.
I tried using a motion frame by creating two fluid domain zones (an outer stationary zone and an inner moving zone enclosing the screen), but the problem persists. I am unsure if the dynamic mesh approach would work here.
Any help or suggestions would be appreciated.
August 20, 2024 at 9:19 am
Forum ModeratorI can't see the domain size, but what do you see if you add an isosurface to show the water free surface and/or phase up the "holes" ?Â
4597
1495
1386
1209
