May 29, 2019 at 9:48 am
Isapu
SubscriberHello Everyone,
I'm working with Ansys Fluent and want to simulate a simple case of laminar fluid flow in a pipe.I would like to receive the pressure drop along the pipe length.
I set up the following properties: - density=1500 [kg/m^3]
- dyn. viscosity=2000 [Pa s]
- length=0,03 [m]
- radius=6,3801*10^-3 [m]
- mass-flow=0,01 [kg/s]
I assigned the entry as mass-flow-inlet and the exit as pressure-outlet with a value of 0 Pa for Gauge Pressure.
The pressure drop through the length in the simulation was 1421070 Pa. I checked the result by a manual calculation with Hagen-Poiseuille-Correlation and had a completely different outcome (614738 Pa).
Does it mean to use Hagen-Poiseuille is not correct?
Kind regards,
Isabella
May 29, 2019 at 12:43 pm
Karthik Remella
AdministratorHello Isabella,
Has your model fully converged? Can you please share some plots of your residuals and monitors?
What does your mesh look like?
Also, does your flow become fully developed? Hagen-Poiseuille equation is applicable for fully-developed flow. Please check the entrance length in your case. If your flow is not fully developed, I suggest you use the fully-developed velocity profile at your inlet, rather than a mass flow rate or velocity inlet condition.
I hope this helps.
Best Regards,
Karthik
May 31, 2019 at 2:00 pm
Isapu
SubscriberThank you for your reply!
" alt="" width="456" height="463">
Element No.: 781500
Element size: 2E-4 [m]
Type: Hex-Mesh
It is confusing! After changing the mesh (element size), I get other results for the pressure drop. I can't imagine what's wrong here.
The pictures below show the velocity vectors. How can I set the fully-developed velocity profile? Is there any tool for at boundary conditions?
May 31, 2019 at 3:50 pm
DrAmine
Ansys EmployeeActually by my carrying out a periodic flow you will get the laminar parabolic profile. Just make inlet and outlet translatory periodic provide flow rate and run it till deep convergence. -
May 31, 2019 at 4:48 pm
DrAmine
Ansys EmployeeOr elongate the pipe wuth at least 0.p5*ReYnolds*Diameter to get it fully developed without periodic
- The topic ‘Flow in a pipe with Hagen-Poiseuille-Correlation’ is closed to new replies.
6410
