September 18, 2023 at 1:11 pm
Marvin
SubscriberI am conducting CFD simulations on a plane in Ansys Fluent. For the circular engine face plane I would like to obtain the 60° segment that has the lowest total pressure. Hence, I would need to create a 60° segment, get the mean pressure value and rotate it by 1° in order to get the 60° area with the lowest pressure along the circumference.
How would I do that?
Regards
MarvinÂ
September 18, 2023 at 3:37 pm
Forum ModeratorI suspect you'll need to get creative with the surface clip tools. Rather than rotating a surface I think you'll need to create some/many faces of 60 degrees and then return the values on those. There are some angular options in the Mesh post processing field variables.Â
- The topic ‘Flow Distortion Calculation (DC60) Ansys Fluent’ is closed to new replies.
Ansys Innovation Space
1388
1188
1095
1015
