June 15, 2021 at 7:14 amcburSubscriber         Hello,  One of our floating license customer receive this error message when running spaceclaim: ANSYS LICENSE MANAGER ERROR Capability ANSYS DISCOVERY Spaceclaim does not exist in the licensing pool  I don't know where to start looking... The license is well installed on the server and we have recovered the diagnostics if it could be useful for you.  They are still on the 19.1 license manager with discovery spaceclaim 19.1  Do you have any idea? (this error message is not in the troubleshooting)
June 15, 2021 at 7:31 amNaresh PatreAnsys EmployeeHello charlie Can you please collect the diagnostics as mentioned in below link and send it to ansys-discovery-support@ansys.com? Discovery Enterprise licensing: Gathering diagnostic information - Knowledge Base - Ansys Discovery Forum
June 21, 2021 at 12:04 pmcburSubscriber
Thank you Mr.KARNOS! The problem has been solved!
The client (under maintenance) has a disco_level1 license that cannot run Spaceclaim 19.1 (which is a disc_ess/disc_sta/disc_ult license)
By upgrading SC and the server license to 2021R1 it works.Summary of the ANSYS answer:Â
I believe the following to be true:
At 19.1, Discovery SpaceClaim needed:
ANSYS Discovery Essentials   disc_essÂ
ANSYS Discovery Standard   disc_staÂ
ANSYS Discovery Ultimate    disc_ult
At 2021 R1, Discovery SpaceClaim needed:
ANSYS Academic Associate Mechanical and CFD Â Â aa_a Â
ANSYS Academic Associate CFD Â Â aa_a_cfdÂ
ANSYS Academic Research Mechanical and CFD Â Â aa_rÂ
ANSYS Academic Research CFD Â Â aa_r_cfd
ANSYS Academic Research Mechanical   aa_r_meÂ
ANSYS Discovery Live Student   aa_s_discÂ
ANSYS Academic Teaching Mechanical and CFD Â Â aa_t_aÂ
ANSYS Academic Teaching CFD Â Â aa_t_cfdÂ
ANSYS Academic Teaching Mechanical   aa_t_meÂ
ANSYS Discovery Essentials Enterprise   disc_essÂ
ANSYS Discovery Standard Enterprise   disc_staÂ
ANSYS Discovery Ultimate Enterprise   disc_ultÂ
Discovery - Level 1 Â Â disco_level1
The license file the customer has looks to be for 2021 R1 and newer.
The license includes: Â Discovery Level 1: Â disco_level1
Which was added at 2021 R1.
- The topic ‘floating license’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
1416
599
591
565
366
