FITDAT NASA polynomial (CHEMKIN)
    • soniacalero86
      I am trying to use FITDAT to convert the NASA polynomial coefficients into the fit Chemkin accepts for the thermodynamic data. The output file does not explain what is wrong. I appreciate your help.
      My input file is:
      DIAG 2               ! print table of data vs. resulting fit evaluation
      TMAX 1000
      POLY NASA      ! expects one set of NASA-format polynomial data
      GACL              Gurvich,1996a pt1 p231 pt2 p186
       2        GA  1.00CL  1.00    0.00    0.00    0.00 0     105.17600    -69621.440
          200.000  1000.000 7 -2.0 -1.0  0.0  1.0  2.0  3.0  4.0  0.0         9609.116
       6.417143000E+03-2.257949147E+02 5.311673690E+00-1.562280975E-03 1.836579731E-06
      -1.100421873E-09 2.725812445E-13 0.000000000E+00-8.593892330E+03-1.695911735E+00
         1000.000  6000.000 7 -2.0 -1.0  0.0  1.0  2.0  3.0  4.0  0.0         9609.116
      -4.864842240E+05 1.452870183E+03 2.719542959E+00 1.144285628E-03-3.431452860E-07
       5.470440480E-11-3.019622103E-15 0.000000000E+00-1.895084035E+04 1.570926145E+01
      END            ! END required to begin processing data
      And the ioutput is:
      WORKING SPACE REQUIREMENTS
                       PROVIDED        REQUIRED
       LOGICAL                  1                1
       INTEGER              112            112
       REAL                  9534           9534
       CHARACTER           1                 1
      This problem requires      0.073MB of memory for the REAL array.
       Reading keyword data...
       Setting DIAG level:                        2
       Setting TMAX:                               6.000E+03 K
       Reading NASA polynomial...
Viewing 0 reply threads
  • The topic ‘FITDAT NASA polynomial (CHEMKIN)’ is closed to new replies.
