April 17, 2024 at 6:31 pm
QUSAI HAMID
SubscriberHi everyone
I want to simulate finger movement by using a tendon, and when I pull the tendon, it will make the finger bend. I tried to make the joint frictionless and the contact between the tendon and body frictional but there was no movement.
I don't know how to define the joint. and contact between the tendon and finger to move the finger.should I use static or transiate analysis ?
I appreciate and thank you all for the help.
April 17, 2024 at 9:44 pm
peteroznewman
SubscriberYou will find some working examples in this discussion.
April 18, 2024 at 7:50 am
QUSAI HAMID
SubscriberMany thanks.
April 24, 2024 at 10:27 am
QUSAI HAMID
SubscriberHello Peter,
This is from your previous comments:
Here is the link to the Ansys 2022 R2 archive. While this shows a rolling joint, your model with joints may be easier to solve because is uses revolute joints. The flexible body version of your finger is going to be much more difficult to solve.
I CANNT OPNEN THE FILE BECAUSE I HAVE Ansys 2022 R1.
April 24, 2024 at 11:41 am
peteroznewman
SubscriberOlder versions of Ansys cannot open files saved in newer versions of Ansys. There is no way to convert newer versions to older versions of a Workbench project file.
You can install the same or any newer version of Ansys to open the Ansys 2022 R2 archive.
May 2, 2024 at 1:37 am
QUSAI HAMID
SubscriberThanks.
- The topic ‘Finger movement by tendon’ is closed to new replies.
5899
1306
