April 23, 2024 at 3:38 pm
fatima ezzahra aouane
SubscriberHello,
I am encountering some challenges while attempting to simulate the flow of water within a pumping station, specifically focusing on the intake of seawater and analyzing the water flow patterns and velocity changes.
When attempting to fill the station with a volume of water, I encountered the following errors:
"Error: Operation would result in non-manifold bodies"
- This error suggests that there may be issues with the geometry of the pumping station, potentially resulting in non-manifold bodies, which could interfere with the simulation process.
"Error: No new fill volume was created from selected body sets"
- This error indicates that despite attempting to fill the station with water, the simulation software was unable to create a new fill volume from the selected body sets, further complicating the simulation process.
These errors are hindering my progress in accurately simulating the water flow within the pumping station. I believe resolving these issues is crucial to obtaining reliable simulation results and gaining insights into the fluid dynamics of the system.
I would greatly appreciate any guidance or assistance you can provide in troubleshooting these errors and ensuring a successful simulation of the pumping station's water flow.
Thank you for your attention to this matter, and I look forward to your prompt response.
Best regards,
April 24, 2024 at 7:03 am
Keyur Kanade
Ansys EmployeePlease check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.Also please consider SpaceClaim for volume extraction. Please check following video.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjh9cWIpNqFAxXGlFYBHRh6CCsQtwJ6BAgbEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D1LBPLfs3QSo&usg=AOvVaw2346wp6Ad8bp6GWtU9k6yr&opi=89978449
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
May 3, 2024 at 12:48 am
Subscriberhello mr keyur, thank u for ur help i really appreciate it. i have another problem I am looking for a way to display depth-averaged quantities such as depth-averaged velocity in my simulation. i hope u can help me hot to display it bcus i couldn't find any really good informationa about it, thank u in advance.
May 3, 2024 at 6:26 am
Keyur Kanade
Ansys EmployeePlease start a new thread under 'Fluids'.
Keyur
- The topic ‘Filling Volume Error In Design Modeler’ is closed to new replies.
6745
1324
1087
