October 23, 2023 at 8:33 am
Roberto
SubscriberHelloÂ
In some versions of 2023R2 when you double click on a scdoc file, SpaceClaim opens but opens a document without the file, how do you fix this problem?
Regards
October 23, 2023 at 9:51 am
Atharv Joshi
Forum ModeratorHi Roberto,Â
Does this occur with all files or is file specific problem? Can you check and let me know if file loads when you Right Click, select "Open with" and select SpaceClaim 2023R2?
Thanks and Regards
Atharv
October 23, 2023 at 10:13 am
Roberto
SubscriberHello Atharv
Questo problema lo fa per tutti i file scdoc, a volte capita che installando una versione nuova del software ci sia questo problema in quanto SpaceClaim non cancella i vecchi file di registro .
Non ricordo quale file di registrazione bisogna modificare per poter risolvere il problemaRegards
October 23, 2023 at 10:14 am
Roberto
SubscriberThis problem occurs for all scdoc files, sometimes it happens that when installing a new version of the software there is this problem as SpaceClaim does not delete the old registry files.
I don't remember which recording file needs to be modified to resolve the problem -
October 23, 2023 at 11:58 am
Atharv Joshi
Can you changing the values in registry editor?
When double clicking a scdoc file to open SpaceClaim it may not be checking the right license. You can add UseLicenseMode into the "Registry editor" to make it work when double clicking a scdoc:-
1) Type in Registroy Editor in Start
2) Locate the following path Computer\HKEY_CLASSES_ROOT\Ansys 2023 R2 .scdoc File\Shell\open\command
3) The value should be something like this "C:\Program Files\ANSYS Inc\v232\scdm\SpaceClaim.exe" "%1" "UseLicenseMode=true"Make sure you back up the registry before making changes. Let me know if this works for you.
Thanks and Regards
Atharv
October 23, 2023 at 12:04 pm
Roberto
thank you very much, problem solved
Regards
October 23, 2023 at 12:40 pm
Atharv Joshi
Forum ModeratorThanks for the update!
- The topic ‘File opening error’ is closed to new replies.
5674
1890
1419
1304
