June 23, 2021 at 6:26 pm
rvpandohie
SubscriberHi,
I've been trying to run a parameter sweep on Lumerical FDTD for a while now (on my lab's desktop) and keep running into the "File not found" error (picture attached)
June 24, 2021 at 12:18 amKyle
This error might be due to some other issue with special characters in the file name, for example the apostrophe. Can you try running it with a file path that has no special characters in it?
June 24, 2021 at 7:02 pmrvpandohie
Subscriberthank you so much, that worked!!
Viewing 2 reply threads- The topic ‘File not found error (parameter sweep)’ is closed to new replies.
4613
1520
1386
1209
