October 17, 2021 at 6:40 pm
Salwa
SubscriberHello,
In FDTD, all simulations stop from the step of initialization and do not go to the analysis mode, although they were working very well before. Do you know what could be the reason for that?
Thanks
October 17, 2021 at 9:55 pmSalwa
SubscriberIt worked when I uninstalled Matlab from the computer. Is there any explanation for that? especially that I need to transfer the data to Matlab.
October 18, 2021 at 5:45 pmLito
Ansys EmployeeWhat is the OS of your machine? Which version of Lumerical and Matlab are you using? If you need to run Matlab on the same computer, and not using the Lumerical Matlab integration, disable the Matlab integration in the Lumerical CAD. Otherwise, set the Lumerical Matlab integration with a supported version of Matlab. You may have to add the Matlab and Lumerical API PATH into your system.
Viewing 2 reply threads- The topic ‘FDTD run problem’ is closed to new replies.
4989
1665
1386
1242
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
