September 5, 2023 at 5:54 pmshaolbSubscriber
We have got the following issues when testing the new GPU solver for FDTD.Â
It seems FDTD is trying to use a folder that does not exist.  "/home/lumerical" for hdf5Â
The /home directory is a network location, and Lumerical cannot use "/home/lumerical" as temp folder. I don't know how to set / change the folder. Â
The error message is below:
/opt/lumerical/v232/bin/fdtd-engine-mpich2nem" -gpu -t 1 "/XXXXX/XXXX/XXXX/XXXX.fsp"
HDF5-DIAG: Error detected in HDF5 (1.8.17) thread 0:
#000: /home/lumerical/temp_hdf/CMake-hdf5-1.8.17/hdf5-1.8.17/src/H5Pdcpl.c line 870 in H5Pset_chunk(): all chunk dimensions must be positive
major: Invalid arguments to routine
minor: Out of range
#000: /home/lumerical/temp_hdf/CMake-hdf5-1.8.17/hdf5-1.8.17/src/H5D.c line 194 in H5Dcreate2(): unable to create dataset
major: Dataset
minor: Unable to initialize object
#001: /home/lumerical/temp_hdf/CMake-hdf5-1.8.17/hdf5-1.8.17/src/H5Dint.c line 455 in H5D__create_named(): unable to create and link to dataset
major: Dataset
......Â
September 7, 2023 at 6:33 pmLitoAnsys Employee
There are certain requirements and limitations when running FDTD with GPU. Not all FDTD simulations will run with GPU. Please see the Knowledge Base (KB) for more information. > FDTD GPU Solver Information – Ansys Optics
- The topic ‘FDTD GPU solver Issues.’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- How to measure transmission coefficients on a given plane .
1236
543
523
225
209
