Photonics
Photonics
fdtd-engine-mpich2nem crashed with SIGSEGV in state_l_rankrcvd_handler()
    • xiaoxuan
      I have run few days long simulation with Ubuntu 20.04 LTS and Lumerical 2023 R2.2. However, it is impossible to finish the few days simulation. The simulation always crashed with an error that APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1). Also, the Ubuntu will report an error liked below. Is there any solution about this situation?
    • Lito
      @Xiaoxuan Ma,
      A quick google search for this error: SIGSEGV could indicate a hardware issue. Check your hardware (run diagnostics on your RAM, MOBO, CPU). Ensure that you disable any power saving features on your Ubuntu machine. If you are running a large/complex simulation that takes a long time to run:
  • The topic ‘fdtd-engine-mpich2nem crashed with SIGSEGV in state_l_rankrcvd_handler()’ is closed to new replies.
