May 17, 2024 at 3:00 pmtavakSubscriber
I am setting up a configuration whose operating frequency is within the RF range, e.g., 1.5 GHz. When I am modifying the source options, the excitation signal curves (both in frequency and time domains) are noisy and irrational. I know there are examples of RF applications for Lumerical FDTD, e.g., Wilkinson power divider. The excitation curves are reasonable and valid for that example. However, in a new fsp file with a 2D FDTD simulation region, when I enter the same values as input signal excitation parameters for a source, wrong and irrational plots are shown as excitation signals. Please see the attached screenshots. I appreciate any help you can provide.
May 17, 2024 at 7:13 pmGuilin SunAnsys Employee
This is a frequently met problem when people setup a RF simulation. The root cause is the default simulation time in FDTD. By default it assumes the source is in optical frequency, so the default simulation time is 1000fs, which corresponds to frequency in a few hundreds of THz. At GHz range, The frequency range is 10^5 lower. Thus you will need to change the simulation time much longger, till the signal is fully showing the pulse.
To avoid very large numerical numbers, you can change the units to be used from "Setting" :
- The topic ‘Faulty excitation in FDTD simulation with a RF exciting source’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- Import material .txt file with script
- Trapezoidal ring
- Help for qINTERCONNECT
- Absorption cross-section of AuNR excited by prism-based TIR
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- How to measure transmission coefficients on a given plane .
- Edge Coupler EME Example Issue
1727
624
599
591
366
