October 25, 2019 at 9:16 pm
mart
SubscriberHi,
Could You please give me instruction how to perform fatigue analysis with the sinusoidal load 1200N, frequency 5Hz. Min load in the load cycle is 200N.
I need to check if the speciment survives 5000000 cycles, determine von mises stresses and principal stresses.
Thanks!
October 26, 2019 at 12:30 am
peteroznewman
SubscriberFirst, you need a material in Engineering Data with S-N curve data that goes out to 5 million cycles. Did you type that correctly? Most S-N curve data stops at 1 million cycles, for example, the Structural Steel that is included in the installation.
1) Build a Static Structural analysis with a static load of 1200 N.
2) Right click on Solution and insert a Fatigue Tool.
3) Edit the Fatigue Tool and set the Loading Type to Ratio
4) Set the Ratio to 200/1200 = 0.166666, Scale Factor = 1.
5) This will cause the analysis to cycle between a maximum load of 1200 (factor 1) and a minimum load of 200 (factor 0.16666).
6) Insert Life into the Fatigue Tool and evaluate.
The cycles to failure in the S-N curve is when 50% of the samples failed.
If the Minimum Life = 5e6 cycles then you predict a 50% probability of survival.
October 26, 2019 at 11:01 am
mart
SubscriberThanks a lot for Your help!
I have one more question. I need to do analysis based on ISO standard, which assumes the use of a frequency between range 1Hz and 30Hz for a cyclic load. How does it affect for the result if I choose for example 5Hz or 25Hz? Where can i change this setting in the simulation?
October 26, 2019 at 3:09 pm
October 26, 2019 at 4:20 pm
mart
Subscriberpeteroznewman thank you for Your help.
Last thing, Is the situation analogous with the increasing torque (20Ncm-40Ncm) in analysis? I need to calculate the ratio and perform the same step or there is another solution?
October 26, 2019 at 4:24 pm
peteroznewman
SubscriberSame process. If the torque is always positive, then the ratio is positive 20/40 = 0.5 and the load in the model must be 40 Ncm.
October 26, 2019 at 4:32 pm
- The topic ‘Fatigue analysis with sinusoidal load’ is closed to new replies.
6450
