Fatal Python error: Py_Initialize: Unable to get the locale encoding
    • Frank Tuzi
      When trying to start Fluent.  The start window appears.   I set working dir, num processors and press start.
      Then the system crashes
      $ fluent
      /opt/ohpc/pub/apps/ansys/v212/fluent/fluent21.2.0/bin/fluent -r21.2.0
      QXcbConnection: XCB error: 3 (BadWindow), sequence: 1007, resource id: 15301673, major code: 40 (TranslateCoords), minor code: 0
      /opt/ohpc/pub/apps/ansys/v212/fluent/fluent21.2.0/bin/fluent -r21.2.0 2d -t12 -pethernet -mpi=openmpi -cnf=/home/ftuzi/Documents/mpiTests/phosts -nm -ssh -license=premium
      /opt/ohpc/pub/apps/ansys/v212/fluent/fluent21.2.0/cortex/lnamd64/cortex.21.2.0 -f fluent -nm -license=premium (fluent "2d -pethernet  -host -alnamd64 -r21.2.0 -t12 -mpi=openmpi -cnf=/home/f
      tuzi/Documents/mpiTests/phosts -path/opt/ohpc/pub/apps/ansys/v212/fluent -ssh")
      Traceback (most recent call last):
       File "/opt/ohpc/pub/apps/python/lib/python3.11/encodings/__init__.py", line 85, in search_function
       File "/opt/ohpc/pub/apps/python/lib/python3.11/encodings/__init__.py", line 64, in normalize_encoding
      AttributeError: 'str' object has no attribute 'isascii'
      /opt/ohpc/pub/apps/ansys/v212/fluent/fluent21.2.0/bin/fluent: line 2761: 147448 Aborted                 (core dumped) $NO_RUN $CORTEX_PRE $EXE -f $FLUENT_PROD $CX_FLAGS "$CX_FUNCTION"
      Any assistance would be greatly appreciated
    • George Karnos
      What is the operating system that is installed?
      Are you running directly on the machine or using a remote viewing software? If remote, what are you using?
    • Frank Tuzi
      Running in Rocky 8.9
      Logging in Via SSH
      using X to view GUIs
    • Frank Tuzi
      Logging in Via SSH
      Thank you  for any assistance that you  can provide
  • The topic ‘Fatal Python error: Py_Initialize: Unable to get the locale encoding’ is closed to new replies.
