November 6, 2024 at 9:55 ama.montesSubscriber
I have a doubt about pressure results in a simulation with two fans in ansys discovery. Fans have been set with predefined fan library (manufacturer data - icepack)
After running the simulation, results show negative values for pressure drop, both static and total.
Thus, having a negative static pressure drop does not match with the fan curve, as the minimum value is zero. Additionally, having a negative total pressure drop has no sense for this system (as far as I undersand).
Could you please help with this matter regarding the results I got and the proper way of evaluating fans in discovery?Add images to show the model.
November 6, 2024 at 10:14 amCharudatta BandgarForum Moderator
Let me check this, a.montes. I will get back to you.
Charudatta B
- Unable to attach geometry 2024 R2
- How to provide blade angles in bladegen.
- plugin error failed to import assembly from spaceclaim
- DXF file loaded incorrectly
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
- Inventor 2025 files
1436
599
591
591
366
