August 30, 2019 at 6:29 pm
adholpure
SubscriberI am working on the project of Modelling of Combustion Process of Internal Combustion Diesel Engine Using Ansys ICE Fluent,Â
As the image below show is from the IC engine combustion tutorial pfd file. But when I reach in ANSYS Fluent after doing all the steps mentioned in the tutorial, I am trying to set the output parameter in the parameter dialog box and I am not getting the same dropdown box as mention in this pdf, attached the Image below.
Instead of this drop-down list, I am getting only one option (from report definition)Â
please help to Identify this problem and finding a solution.
August 30, 2019 at 6:31 pm
adholpure
SubscriberI also attached the Pdf file in the chat above which I followed
September 2, 2019 at 10:57 am
Forum ModeratorCan you create the Report Definitions in the model and then promote those to parameters?
September 7, 2019 at 6:08 am
adholpure
Subscriberactually, sir, I am a little bit confused about how to create a report definition
- The topic ‘Facing problem in setting output parameter in simulating Combustion in ANSYS IC Engine Fluent’ is closed to new replies.
4628
1535
1386
1215
