November 21, 2018 at 6:38 pm
sana ullah
Subscriber HI I am facing a problem with a linear machine. The problem is that its giving me the error of "Moving objects touch the stationary shell" though both the moving objects and stationary objects are totally separate from each other, even the bands assigned to them are separate from each other. It also says that "Motion setup (geometry) is not valid" , i am not sure why,can anyone help please.
regards
December 26, 2018 at 7:50 pm
Xiaoyi Zhao
Ansys EmployeeHi Sana, have you made sure that the motion limit are totally contained within the band? The moving part cannot touch the band either.
November 4, 2019 at 9:50 pm
aicha1
Subscriberhello, I am sorry have you solved this problem?
November 4, 2019 at 10:59 pm
aicha1
Hello everyone,
I tried to assign the band for a linear motion. However, the simulation generates an error "Moving objects touch the stationary shell at initial position" even though the initial position is within the band and this latter does not touch the objects. Could anyone please help me?
Thank you in advance!
November 20, 2019 at 2:32 am
aishahzuki
SubscriberHi everyone.
I had tried to assign band for linear motion but have 2 problems which are:
1) Invalid moving objects. All moving objects inside band must from single connected region.
2) Motion setup (geometry) is not valid.
Can anyone help me because i had tried many ways but the problem still the same.
November 20, 2019 at 11:24 am
mbeliaev
Ansys Employeefor such kind of issues you need first check following things:
1) it should be one vacuum object that covers all other objects (like inner_band). So only one moving object will be present.
2) Motion limits
3) geometry intersections
4) fine mesh in the band
Best regards,
Maksim Beliaev, M.Sc.
Electromagnetics and Optics Community Manager, Europe -
January 7, 2023 at 7:33 am
Selin Kocaoglu
SubscriberI am facing this problem,but I could not understand your solution suggestion What does 'fine mesh in band' mean?
- The topic ‘Facing problem in linear machine’ is closed to new replies.
5694
1891
1419
