July 28, 2021 at 8:48 pm
Pratik.Ghate
SubscriberHello,
I installed Ansys Electronics 2021 R1. I am trying to distribute tasks on different machines with Intel MPI, but the process does not go beyond "Determining memory availability on distributed machines on local machine". All the machines are on the same domain. I did test machine and all the tests were successful.
Also this setup works perfectly in 2019R3 with IBM MPI. Not sure what is going wrong. Can someone please help me figure this out?
Thanks,
Pratik
August 3, 2021 at 1:03 pmVivekKamble
It seems you opened a service request on the customer portal and one of our engineers is working with you to get this out fix.
So, please follow the service request and we would like to offer you support on the service request channel as this issue needs more diagnostics and research.
Thanks Vivek
September 29, 2021 at 3:25 pmjona
SubscriberHello!
I have the same problem with Ansys Electronics Desktop 2021 R2 and RMS and would be interested in how you solved the issue.
Could you please share your solution?
Thanks and best regards Jona
October 1, 2021 at 1:13 amAndyJP
SubscriberI had some troubles in the past with versions 13-15. There were TCP ports necessary to open, not properly documented in the manual. Try disabling firewalls completely, for determining, is it the case. RMS and the EDT should be of the same version, btw.
October 1, 2021 at 5:23 pmPratik.Ghate
SubscriberI disabled all the firewalls and registered my credentials on each node using command prompt.
"%I_MPI_ROOT%"\intel64\bin\mpiexec -register
Hope this helps!
Viewing 4 reply threads- The topic ‘Facing issues while distributing the tasks on different machines’ is closed to new replies.
5719
