f1 process could not be started in parallel mode of fluent
    • Weiqiang Liu
      Hi all,
      In my case, I have 20  macros in source code. I can run under serial mode without any error. However, when I build, load and hook my source code under parallel mode, fluent complains about error 'f1 process could not be started'
      I wonder what is the reason for this. Do I have to modify my UDF under parallel mode? Or some other reasons for this?
      Best.
      Weiqiang
    • DrAmine
      Actually parallelization is generally required whenever threads are passed or you want to read or write something or you rely on global reductions. Can you debug each macro or part alone? Check especially profile aNd adjust macros.
    • Weiqiang Liu
      Hi Amine,
      I debugged my code line by line. I found udf returned right value under serial mode. However, fluent complained error like 'f1 process could not be started'
      Do I have to modify my source code because of parallel reason?
      Best.
      Weiqiang.
      Maybe: are any of the macros/terms listed in the Parallelisation chapter of the manual?
    • Weiqiang Liu
      Hi ,
      do you mean I have some macros or items in the source code that are customized for parallelisation? I have the following macros in the code:
      DEFINE_SOURCE
      DEFINE_PROFILE
      DEFINE_PROPERTY
      By the way, I have UDS in my model and I use IF(THREAD_ID(t)==zone_ID) to recognize different zones.
      Best.
      Weiqiang
Viewing 4 reply threads
  • The topic ‘f1 process could not be started in parallel mode of fluent’ is closed to new replies.
