February 19, 2019 at 4:14 pm
rlsnedeker
SubscriberHello I am just started using the software.
So I am very new, I have a decent background in other CAD Programs.
I watched the tutorials on lip shape and duplicated what I saw but I have an issue that maybe the narrator did not cover.
I made a simple geometry and under physics regions I have an error which states "disconnected (group of0 bodies found. see the adding region interface conditions for polymer extrusion simulations" section in the help for details.
Clicking on help changes the box on the right of the screen however the box is empty.
so I tried adding a interface condition (region interface). doing so eliminated the physics region error, however when I start adding fluid flow conditions and then get an error region interface is adjacent to a die deformation, which is not allowed. Define a multi-body part with connected bodies. see "considerations for region interfaces and polymer extrusion" in the help for details. again clicking on help does not do anything.
I just need to figure one out. Any help would be appreciated. thanks in advance
February 20, 2019 at 2:04 pm
rlsnedeker
SubscriberAre there actual manuals for these cad programs. The video tutorial is not helpful in this situation. If anyone has any advice i would appreciate it.
February 20, 2019 at 4:59 pm
rlsnedeker
Subscriberwhy have a blank help button?
February 22, 2019 at 7:30 am
Naresh Patre
Ansys EmployeeHello rlsnedekerÂ
Regarding extrusion problem, you need to have mesh connectivity between the die and extrudate. To get this, open the geometry in SpaceClaim and under Workbench tab, click "Share" to connect the bodies. Now import this geometry. You will now see that the generated mesh is connected near the die and extrudate interface. Next, if you go to Physics regions, you will no longer get the message of disconnected bodies.
Regarding help button issue, I am not sure what could be the issue. Can you try visiting https://ansyshelp.ansys.com/ and see if you are able to access the help section?
February 22, 2019 at 12:57 pm
rlsnedeker
SubscriberIs there a student ver. of SpaceClaim?
February 22, 2019 at 1:00 pm
rlsnedeker
Subscriberis there a way to do this in another student program?
February 25, 2019 at 6:37 am
Naresh Patre
Ansys EmployeeI guess the student version of SpaceClaim can be accessed under ANSYS Student product bundle.
Discovery Live can also be used for doing SpaceClaim operations as it contains all SpaceClaim tools.
February 25, 2019 at 2:26 pm
rlsnedeker
Subscriber thank you for helping me with that issue, however I believe I now have a license issue. Does the students version have extrusion die lip prediction?Â
I am getting the following message . "update failed for the solve physics component in study. the solution task update failed see the error message for more details."then below it says physics 1: ansys license not available" any idea how to move forward?
February 25, 2019 at 2:31 pm
February 26, 2019 at 7:33 pm
Steve
Ansys EmployeeHi,
Can you go to the folder: %TEMP%/.ansys, find the file: henlicdebug.STUDY_MESH.192.out, t copy and paste its contents into this discussion?
Steve
February 27, 2019 at 12:50 pm
rlsnedeker
Subscriberwhere would I find that?
February 27, 2019 at 12:52 pm
rlsnedeker
SubscriberI am not sure where to find that. once I find it I will do that
February 27, 2019 at 7:55 pm
Konstantin
Ansys Employee%TEMP% is a temporary folder on your windows machine, type %TEMP% in Search, and it'll point it to you. The full path will be something like:
C:UsersusernameAppDataLocalTemp
February 28, 2019 at 1:02 pm
rlsnedeker
SubscriberI did not find a henlicdebug.STUDY_MESH.192.out
but I did find licedebug.study_mesh.192 which has this in it
2019/02/19 10
7
8Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/19 10
7
8Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/19 10
7
8Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65988:10.0.0.109Â Â Â
2019/02/19 10
7
8Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 57218@localhost.
2019/02/19 10
7
8Â Â Â CHECKOUTÂ Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65988:10.0.0.109Â Â Â
2019/02/19 10
7
9Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 7848:10.0.0.109Â Â Â Â
2019/02/19 10
7
9Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to local server: 57220@localhost.
2019/02/19 10
7:40Â Â Â CHECKINÂ Â Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/0/0/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65988:10.0.0.109Â Â Â
2019/02/19 11
8:44Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65988:10.0.0.109Â Â Â
  License server 57218@localhost has disconnected unexpectedly.
     ANSYSLI_SERVERS:Â
     FLEXlm Servers: C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic
2019/02/19 12:02:12Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/19 12:02:12Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/19 12:02:12Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/3/6/6Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
2019/02/19 12:02:12Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 57218@localhost.
2019/02/19 12:02:12Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/3/6/6Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
2019/02/19 12:02:12Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/3/6/6Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
  License server connection restored.
  Connected to server 57218@localhost.
     ANSYSLI_SERVERS:Â
2019/02/19 12:50:09Â Â Â HEARTBEATÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
  Connection to peer closed unexpectedly while receiving data.
2019/02/19 12:50:10Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/19 13:19:55Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/19 13:19:55Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/19 13:19:55Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/8/10Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66120:10.0.0.109Â Â Â
2019/02/19 13:19:55Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 57218@localhost.
2019/02/19 13:19:55Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/8/10Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66120:10.0.0.109Â Â Â
2019/02/19 13:19:55Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/8/10Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66120:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/19 13:41:04Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66120:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/20 08:41:54Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/20 08:41:54Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/20 08:41:54Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/13/13Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66152:10.0.0.109Â Â Â
2019/02/20 08:41:54Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 57218@localhost.
2019/02/20 08:41:54Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/13/13Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66152:10.0.0.109Â Â Â
2019/02/20 08:41:54Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/13/13Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66152:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/20 09:12:08Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66152:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/20 09:13
2019/02/20 09:13
2019/02/20 09:13
8Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/2/2/2Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 09:13
8Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 58668@localhost.
2019/02/20 09:13
8Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/2/2/2Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 09:13
8Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/2/2/2Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
  Connected to server 58668@localhost.
     ANSYSLI_SERVERS:Â
2019/02/20 09:55:19Â Â Â CHECKOUTÂ Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/2/6Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 09:55:20Â Â Â CHECKINÂ Â Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/0/0/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/2/6Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 10:28
7Â Â Â CHECKOUTÂ Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/2/6Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 10:28
9Â Â Â CHECKINÂ Â Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/0/0/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/2/6Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 11:21:48Â Â Â CHECKOUTÂ Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/2/10Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 11:21:50Â Â Â CHECKINÂ Â Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/0/0/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/2/10Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
2019/02/20 12:15:58Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65472:10.0.0.109Â Â Â
  License server 58668@localhost has disconnected unexpectedly.
     ANSYSLI_SERVERS:Â
2019/02/21 07:45:10Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/21 07:45:10Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/21 07:45:10Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/12/14Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65796:10.0.0.109Â Â Â
2019/02/21 07:45:10Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 58668@localhost.
2019/02/21 07:45:10Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/12/14Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65796:10.0.0.109Â Â Â
2019/02/21 07:45:10Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/5/12/14Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65796:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/21 10:59:25Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65796:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/21 10:59
2019/02/21 10:59
2019/02/21 10:59
8   INFO               C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_client.exe -demo -log C:UsersRS302AppDataLocalTemp.ansysdemo.log
2019/02/21 10:59
8Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Started ANSYSLI server.
2019/02/21 10:59:51Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/2/1/2Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65456:10.0.0.109Â Â Â
2019/02/21 10:59:51Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 61884@localhost.
2019/02/21 10:59:51Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/2/1/2Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65456:10.0.0.109Â Â Â
2019/02/21 10:59:51Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2/2/1/2Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65456:10.0.0.109Â Â Â
  Connected to server 61884@localhost.
     ANSYSLI_SERVERS:Â
2019/02/21 11:23:47Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65456:10.0.0.109Â Â Â
  License server 61884@localhost has disconnected unexpectedly.
     ANSYSLI_SERVERS:Â
2019/02/21 12:22:10Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/21 12:22:10Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/21 12:22:10Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/4/6/7Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66020:10.0.0.109Â Â Â
2019/02/21 12:22:10Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 61884@localhost.
2019/02/21 12:22:10Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/4/6/8Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66020:10.0.0.109Â Â Â
2019/02/21 12:22:10Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 4/4/6/8Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66020:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/21 12:57:09Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66020:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/22 07:46:41Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/22 07:46:41Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/22 07:46:41Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/5/13/14Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
2019/02/22 07:46:41Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 61884@localhost.
2019/02/22 07:46:41Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/5/13/14Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
2019/02/22 07:46:41Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/5/13/14Â Â 7580:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66044:10.0.0.109Â Â Â
     ANSYSLI_SERVERS:Â
2019/02/22 10:51:29Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/22 10:51:29Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/22 10:51
0Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/14/14Â Â 33736:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66088:10.0.0.118Â Â Â
2019/02/22 10:51
0Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 64163@localhost.
2019/02/22 10:51
0Â Â Â CHECKOUTÂ Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/14/14Â Â 33736:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66088:10.0.0.118Â Â Â
2019/02/22 10:51
0Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/5/5/5Â Â 33736:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 7640:10.0.0.118Â Â Â Â
2019/02/22 10:51
0Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to local server: 64970@localhost.
2019/02/22 10:51
2Â Â Â CHECKINÂ Â Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/0/0/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/14/14Â Â 33736:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66088:10.0.0.118Â Â Â
2019/02/22 12:51:15Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/22 12:51:15Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/22 12:51:15Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 9532:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65992:10.54.60.83Â Â
2019/02/22 12:51:15Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 49197@localhost.
2019/02/22 12:51:15Â Â Â CHECKOUTÂ Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 9532:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65992:10.54.60.83Â Â
2019/02/22 12:51:15Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 9532:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 7836:10.54.60.83Â Â Â
2019/02/22 12:51:15Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to local server: 49200@localhost.
2019/02/22 12:51:17Â Â Â CHECKINÂ Â Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/0/0/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 3/3/4/4Â Â 9532:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65992:10.54.60.83Â Â
2019/02/23 09:28:40Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/23 09:28:40Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/23 09:28:40Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/5/5/5Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65980:192.168.0.11Â
2019/02/23 09:28:40Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 51177@localhost.
2019/02/23 09:28:40Â Â Â CHECKOUTÂ Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/5/5/5Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65980:192.168.0.11Â
2019/02/23 09:28:40Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/5/5/5Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 7832:192.168.0.11Â Â
2019/02/23 09:28:40Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to local server: 51184@localhost.
2019/02/23 09:28:43Â Â Â CHECKINÂ Â Â Â Â Â Â Â Â Â Â Â STUDY_MESHÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 19.2 (2018.0721)Â Â Â Â Â Â Â Â Â Â Â Â 1/0/0/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/5/5/5Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65980:192.168.0.11Â
2019/02/23 14:23:17Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 65980:192.168.0.11Â
  License server 51177@localhost has disconnected unexpectedly.
     ANSYSLI_SERVERS:Â
2019/02/23 14:24:40Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
2019/02/23 14:24:40Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Starting demo server.
2019/02/23 14:24:40Â Â Â CLIENT_CONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/11/11Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66036:192.168.0.11Â
2019/02/23 14:24:40Â Â Â NEW_CONNECTIONÂ Â Â Â Â Connected to demo server: 51177@localhost.
2019/02/23 14:24:40Â Â Â RECONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/11/11Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66036:192.168.0.11Â
2019/02/23 14:24:40Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/11/11Â Â 9284:STUDY_MESH:RS302@MSI:winx64Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 66036:192.168.0.11Â
  Connected to server 51177@localhost.
     ANSYSLI_SERVERS:Â
2019/02/23 20:47:06Â Â Â SERVER_DISCONNECTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â &nb -
February 28, 2019 at 1:17 pm
rlsnedeker
SubscriberI found this which I hope is the same thing.
rlsnedeker
SubscriberThank you for the Help. Is this the same thing?
March 1, 2019 at 12:47 pm
rlsnedeker
Subscriberis this Right?
March 1, 2019 at 1:27 pm
rlsnedeker
SubscriberHow do I proceed?
March 1, 2019 at 2:24 pm
Steve
Ansys EmployeeOne more thing to check, the student license is limited to a mesh of 1 million cells, or 50 bodies, or 300 faces. Does your mesh or geometry exceed these limits?
Someone will get back to you about the licensing file.
Steve
March 1, 2019 at 4:28 pm
rlsnedeker
SubscriberWhere would you check for the mesh count?
If I am doing a die lip prediction under polymer extrusion,Â
after importing geometry you produce a mesh would u check there?
If that is the issue, can you limit the mesh count or just change the mesh size?
That's if I don't have a license issue.Â
Sorry for my lack of experience with Ansys but I appreciate everyones assistance with these issues.Â
Ansys has already changed the way I am going about my capstone project for school.
March 5, 2019 at 12:47 pm
rlsnedeker
Subscriberany ideas would be helpful
March 5, 2019 at 12:48 pm
rlsnedeker
SubscriberSo I checked and I don't believe that my meshes exceeded that .
March 5, 2019 at 3:50 pm
rlsnedeker
Subscriberthe geometry was simple it was an l shape. it had 6 faces
March 6, 2019 at 3:26 pm
rlsnedeker
SubscriberAny advice here?
September 12, 2019 at 4:55 pm
jix218
SubscriberHi nmpatre,
I am trying to follow your step to 'share' the two body. I am using discovery live to modify my geometry but I could not find the workbench tap as well as the share button. Could you be more specific about where I could find these two buttons?Â
Thanks
- The topic ‘Extrusion Difficulties’ is closed to new replies.
6044
