November 6, 2023 at 8:46 pm
November 7, 2023 at 6:11 am
Charudatta Bandgar
SubscriberDamian,
If your curves are continous closed loop, you should be able to use the fill option to fill the surface. Are you facing any issues? If the fill option is not working, it is possible that it is not closed. Once it is filled to create a surface, it can be extruded using pull feature.
Charudatta
- The topic ‘Extruding imported “curves”’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1495
1386
1209
