July 26, 2019 at 6:40 pm
pranav5
SubscriberHello,
I'm studying Si die/chip warpage and forces required to flatten them (Image of the schematic is attached). The dimensions of the die are 10,000 um length, 6000 um width and 300-700 um thickness. The die warpage is 0.1-1 um.Â
When I sketch such geometry in DesignModeler and try to extrude it along the width, I get:
Error: No profiles could be swept along the selected direction vector
Context: Extrude Feature Extrude2
How can I fix this?Â
Thanks,
Pranav
July 26, 2019 at 8:19 pm
August 1, 2019 at 6:53 pm
pranav5
SubscriberThanks, Peter. I've updated the post as per your suggestion.
August 2, 2019 at 1:58 pm
Forum ModeratorYou've probably run of of significant figures in the CAD tolerance/accuracy. Try building it so warpage is 1cm, and die length is 10,000 cm.  I assume you can rescale in Mechanical?Â
If that doesn't work can you squash the die length (scale) to build the model and then stretch (scale) in Mechanical once it's meshed?Â
- The topic ‘Extrude error in DesignModeler’ is closed to new replies.
6465
