January 21, 2024 at 12:24 pm
ANSYS EXPLORER
SubscriberDear Experts,
I am doing a vibration analysis of a Column and intended to extract the Froce reaction and moment reaction at a specified points (One is at top of the column and another point is at 3/4 height of the column where the force is applied) for a given frquency range (0 to 5 Hz) in Harmonic Analysis using ANSYS Workbench. When i use the frequency response probe for extracting the reaction & moment for at the selected remote points, the results are coming zero values.
Note : The column is modeled with Line element and ensured stiffness and mass distribution as required.
Requesting your values inputs.
Thank you in advance.
Regards
AE
January 21, 2024 at 2:01 pm
peteroznewman
SubscriberYou can request the frequency response at any node/point for displacement, velocity or acceleration including point A where you apply a force.
You request reaction forces at any node/point where you apply a support or displacement.
Reaction forces are expected to be zero if there is no support or displacement at the node/point.
- The topic ‘Extracting force reaction and moment reaction – Harmonic Analysis in ANSYS WB’ is closed to new replies.
6450
