September 24, 2018 at 11:25 pm
birbara2
SubscriberHello, I am trying to import a pcb ( Cadence brd file) to icepak but I am getting an error saying "could not find application extracta.exe". I tried to add it to the path in libraries but does'nt seem to work. Help?
October 17, 2018 at 7:51 pm
3Asif
SubscriberHi there!
The extracta.exe is not useful as a 'library'. Instead the tool (Icepak) needs to know where the software is when the translation is needed if you think like a software).Â
The extracta.exe has to have an environment variable declared in the operating system (OS). Whenever other tools need the translation, that till will ask OS to using that environment variable and get that exe to do the work.
Online, I have seen fewenvironment variables suggestions:
"Add the path to the Extracta location to your PATH environment variable."
To accomplish it:
set CDSROOT=C:Cadence{continue Sub-Folder, but doo not go too deep. It can be one level higher than tools folder}
set PATH=%PATH%;%CDSROOT%bin;%CDSROOT%toolspcbbin
Disclaimer: I have not tested it myself. If you have found your own solution, you may share with the world (and be thanked eternally!)
Cheers,
3A
February 9, 2023 at 1:40 am
Eric Chojnacki
SubscriberÂ
1)Â The Cadence Allegro software must be installed to get the extracta.exe utility. Â Maybe a copy of the extracta.exe utility obtained from a different pc can be installed in any directory, or a manually created Cadence directory structure. Â A typical path is C:\pcblib\apps\allegro\SPB_17.4\tools\bin\extracta.exe.
2)Â The system environment path variable must have the addition of this extracta path.
    a. In your pc Window Settings tool (gear symbol), search for environment and select something like Edit the system environment variables, or otherwise get to the System Properties popup, then click the button at the bottom Environment Variables…
3) In the lower half of the next popup under System variables click the variable Path and click the button Edit…
4) In the the next popup click the button on the right New and the next line in the list of paths will be editable, then paste the extracta path, such as C:\pcblib\apps\allegro\SPB_17.4\tools\bin and click OK‘s to close the 3 popups.  Re-boot your pc to enact the added system path.
5) Now that extracta.exe is installed and on your system path, open ANSYS EDT, click menu File > Import > Cadence APD/Allegro/SiP… and select your .sip file to be imported.
6)Â In the next popup check boxes to define any desired ports and such.
7)Â To make the imported wireframe-type model more legible, click the menu View > Display Mode > Solid.Â
August 8, 2023 at 5:00 pm
Muhammad Hamza
SubscriberTry closing everything (cadence + hfss) and then:
1. Open the .brd file in cadence allegro and keep it opened.
2. Then start HFSS and try to import the same .brd file again.
This worked for me. Hope it helps!
- The topic ‘extracta.exe for icepak pcb file’ is closed to new replies.
6344
