September 27, 2024 at 7:21 am
mitchell.payn
SubscriberHello,
Is there a way to extend the region to which the simulation will provide results.ÂI have an antenna and have run the simulation. I then create an object, right click on the object and plot the mag_E. the feilds strengh is shown in a gradient style but is limited to within 140mm of the antenna. I am looking to see values further out to about 1 meter. If a draw a polyline on this plane, I can graph the results in a 2D graph. No mater how big of an object I draw, there seems to be a cap on the region it will provide results for.Â
September 27, 2024 at 2:01 pm
AncS
Ansys EmployeeHello Mitchell,
You can use the 'create region' command to create an automatic adjustable simulation region from the 'Draw' ribbon. You can set the desired padding for it in all the directions.Â
Hope this will help.
Regards
Anchal
5779
