November 11, 2024 at 9:23 am
OAnderson
Subscriber -
November 11, 2024 at 1:26 pm
Federico
Ansys EmployeeThis expression is a function of Static Temperature, so indeed it does not evaluate to a single value and you will not get an output from the Expression window. It does not mean however that this is a problem. Try initializing your solution and do a Contour plot for this expression to check that it evaluates to the right range.
November 12, 2024 at 11:09 am
Forum ModeratorAs an observation, how did you generate that polynomial? Just curious if you'd be better off with piecewise linear or similar depending on rounding error.Â
1307
