Electronics
Electronics
Exporting to File the Fair Field results from Broadband Frequency Sweep
    • raul
      I am writing to ask if there is a practical way in HFSS / HFSS-IE to save to a file (txt, csv, etc.) the antenna far field results (for instance, the total gain) from a broadband frequency sweep analysis, which produces results at hundreds of frequencies.
      For instance, if the simulation is done from 100 to 300 MHz, at discrete frequencies every 1 MHz, I want the output file to contain the total gain at every frequency, theta, and phi:
      freq,    phi,    theta,   gain
      100 MHz,   -180, 30,  5.1
      100 MHz,   -180, 31, 5.2
      101 MHz,   -180, 30, 4.3
      200 MHz,   180, 180, 3.0
      I know how to export results to a file from plots. But doing this would be very impractical if I had to save results for hundreds of frequencies.
      Thank you in advance!
      Raul
    • Sorceress Gia
      Hi Raul,
      You can do this with scripting - Go to 'Tools -> Record Script to File' - Now every action you do in HFSS will be recorded to a script file. - When you're done, go back to this menu and select 'Stop Recording' - Use this information to create your own custom script to automatically export all of your far field data...
    • raul
      Thank you very much Peter. I was able to make this work at least for simple tasks. I will continue trying until I automate the process in the way that is most efficient for my application.
      Thank you very much
      Raul
  • The topic ‘Exporting to File the Fair Field results from Broadband Frequency Sweep’ is closed to new replies.
