May 13, 2024 at 7:49 am
deepesh.p.gurdasani
SubscriberAfter exporting from CAD software to ANSYS in .stp or even opening direct .prt file in spaceclaim, I have seen number of times that there is some minute change in design, may be a data loss because of which either a particular part's angle w.r.t origin changes or there comes some interference issue (might be because of this minute change in design). The minute change can be as low as 0.0000001 but this could create an issue.Â
Is there any way that this minute change doesnt happen ? any particular settings that need to be taken care of while exporting from CAD software as .stp file ?
Thanks in advance
May 13, 2024 at 10:10 am
Willie Tillmon
SubscriberÂ
Use Recommended Formats, for example, exporting to Parasolid format before importing to ANSYS may result in less translation error
May 14, 2024 at 2:31 am
deepesh.p.gurdasani
SubscriberAny list of recommended formats that I should try ? Preference wise list would be helpful.
Thanks.
May 14, 2024 at 11:55 am
Sampat Kumar
Ansys Employee-
May 16, 2024 at 8:38 pm
deepesh.p.gurdasani
SubscriberTried changing these options but still there is data loss. Any other suggestion regarding this?Â
May 15, 2024 at 2:42 pm
deepesh.p.gurdasani
SubscriberSo basically if I de select 'improve imported data' , Space claim will import it just as it is ?
May 16, 2024 at 9:47 pm
deepesh.p.gurdasani
SubscriberIf anyone can guide regarding this?
Thanks
- The topic ‘Exporting from CAD software to ANSYS’ is closed to new replies.
