3D Design
3D Design
Exporting file in STEP or IGES format
    • Assassin
      Hello Everyone, So I'm trying to repair a 3D scanned data in Spaceclaim and I've imported it as STL file. Now i need to export it to STEP or IGES format for adding some geometry in Creo or Sketchup. But I'm not able to export in both the formats. Any leads would be highly appreciated. I'm using student version.TIA
      You'd need to patch the surface to create a NURBS shape. Otherwise you'd be exporting every single facet as a face: that almost certainly won't work.
      Moved to Geometry section.
    • Keyur Kanade
      following may help you.
      https://www.youtube.com/watch?v=8BDoYRm9yf0
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • Gulafsha
      I have same question.
      Please guide
  • The topic ‘Exporting file in STEP or IGES format’ is closed to new replies.
