November 30, 2023 at 8:47 am
Admin Admin
SubscriberHi,
I've created a Power Syntax script for post-processing transient CFD results from Fluent with 200 timesteps in CFD-Post. The script creates ~200 planes for which it uses the in-built massFlowAve function to calculate their mass flow-weighted average temperatures which will then be applied as reference temperatures in conjunction with y-plus heat transfer coefficients to a thermo-mechanical FE model. I set the script up to tabulate the data in the Table Viewer and then export them as a .csv file but have realised the limits of columns / rows is nowhere near large enough to accommodate the amount of data. Is there a way to extend the limits of Tables in Table Viewer? Alternatively, is there a better way to export the data as a .csv file?
Many thanks for any help.
Jason
December 7, 2023 at 6:41 pm
rfblumen
Ansys EmployeeThe Table Viewer is limited to 200 rows and 26 columns (A-Z). With a larger amount of data, I would modify the script to directly export the data to a .csv file that could then be opened and post-processed in Excel. If you need assistance modifying your script to do this, please submit an Ansys service request and a support engineer can assist you.
- The topic ‘Exporting data from CFD-Post using Power Syntax script’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
