September 20, 2018 at 3:03 pm
birbara2
SubscriberHello, Can I export contour data to matlab? It doesn't have to be as much high resolution as the mesh.
Thanks
September 20, 2018 at 5:51 pm
raul.raghav
SubscriberAssuming that you're using Fluent, there two ways of doing it:
1. From Fluent:
File > Export > Solution Data; File Type: ASCII, and select the appropriate contour plane with the specific contour variable of interest along with the plane coordinate axes. This will export the data into a csv file which can be imported in MATLAB.
2. From CFD-Post:
File > Export > Export...; Type: Generic, and select the required surface with the variable of interest. This will create a csv file which can be imported into MATLAB. If your mesh is too fine and if you don't need all the data, you can "Insert > Point Cloud" at the selected surface which the required point density and you can export this Point Cloud the same way as mentioned earlier.
November 16, 2020 at 4:21 pm
sailesh1312
SubscriberBut what if we want force as our desired variable?n -
August 9, 2023 at 10:38 pm
Yvette Law
SubscriberHi there, how to make it process automatically so I dont need to open the case one by one ?
August 10, 2023 at 11:50 am
Forum ModeratorYes and no. You will need to open the case & data, but with journals you can automate the whole process.Â
- The topic ‘Exporting contour data to matlab’ is closed to new replies.
6625
1311
