March 8, 2024 at 1:28 pm
Jose Amigo
SubscriberHi everyone,
I currently have multiple .dat files from a transient simulation, which I want to use in CFD post to create an animation. I wrote a journal file to read and write these files as ".cdat" and ".cas". When I use the GUI (picture below), everything works ok. However, if I do it through TUI, I only get the ".cdat" file and not the ".cas" file.
This is the command I use in the TUI.
/file/export/cdat-for-cfd-post-&-ensight filename cellzone_name () density quit yes
If I write it as binary or ASCII it doesn't make a difference (yes/no at the end). I wonder if the "quit" is causing problems, which I use when the console asks for the second scalar, but I only have one.
Any ideas are fully appreciated.
José -
March 8, 2024 at 1:49 pm
Forum ModeratorThat doesn't look to be quite the right command,
/file/export-to-cfd-post myfile () zone or zones () field-1 field-2 etc quit noÂ
March 8, 2024 at 8:32 pm
Jose Amigo
SubscriberHi Rob,
Thanks for the reply.
I tried your command and apparently it does the same as cdat-for-cfd-post-&-ensight. However, I noticed the following: the first time I execute this in the TUI, it writes both .cdat and .cas files, but if I continue doing it will only keep saving .cdat files. It only works 1 time. It will only save the .cas file again if I close and re-open Fluent.Â
March 11, 2024 at 9:56 am
Forum ModeratorIf there's no change to the mesh that's normal, if you're changing mesh I'd always save case & data (not cdat) too. cdat is a cut down format too, so you can't restart a Fluent run with one.Â
- The topic ‘Exporting .cdat and .cas files using TUI’ is closed to new replies.
3044
971
858
852
792
