Exporting a specific temperature data from fluent analysis as a .csv file
    • MertCelen
      Hello everyone,
      I did a transient simulation of chip and heat sink, but I need to export transient temperature data for some specific locations. However, I need to export this files as a .csv file so I can plot 2D graph temperature vs time for each of those locations. If there is no change to export data as .csv, is it possible to plot a 2D graph temperature vs time for each of those locations? I already checked user manual's but I couldn't find appropriate solution for my case.
      Kind Regards,
      Mert Çelen
    • DrAmine
      If you can go step back then you can create a report definition at certain point, use vertex average to reduce the quantity and enable write file you will be able to have an output file which can be used in third party programs.
  • The topic ‘Exporting a specific temperature data from fluent analysis as a .csv file’ is closed to new replies.
