May 4, 2021 at 8:36 am
Lukas8778
SubscriberHey there,
I want to do a thermal analysis of a PMSM using ANSYS Workbench/Fluent. When I try to import the maxwell file into the Workbench environment I don't have the option to select Maxwell /aedt files.
I'm using a full version of ANSYS Electronics 2021 and also a full version of ANSYS Workbench 2021.
Can anyone help?
Thank you very much
Greetings Lukas
May 4, 2021 at 12:40 pmKarthik Remella
AdministratorHello You will need to use the 'System Coupling' here for this. Please look at the following tutorials here on Ansys Help.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/prod_page.html?pn=System%20Coupling&pid=SystemCoupling&lang=en&prodver=21.1
Karthik
October 3, 2023 at 8:37 amπ dix
Ansys EmployeeHello,
To link an Electromagnetics Suit (Ansys EM) release with Ansys Workbench of same generation, you have 2 possibilities:- Either during the installation of Ansys EM 2XRY (only if Ansys Workbench 2XRY is already installed on your station), you confirmed your wish to integrate Ansys EM in workbench
- Or, once all software of same release are installed: In the START menu of Windows; In the installed file Ansys EM Suite 202XRY > Modify Integration with Ansys 202XRY
Then, you can start coupling simulation: Electromagnetics > Thermal/Mechanical
Pierre
Viewing 2 reply threads- The topic ‘Export of Maxwell Model in Workbench’ is closed to new replies.
5639
1885
1403
1303
