Ansys Products
Ansys Products
Export Mesh/Object as CBD
    • Peter Noonan
      Hello, I am quite new to ANSYS and am looking for some help. I am building a FE model in ANSYS workbench and which to export the created mesh as a .CBD file. I have used a .stl to export the mesh prior but it does not keep information on surfaces ( which is a must). Thus, I need to know how I can can mesh a geometry, and then export it is a cbd file.
    • Aniket Chavan
      Do you mean cdb file? How are you going to use this cdb file?
      Please check the following:
      /knowledge/forums/topic/how-to-export-cdb-from-mechanical-without-solving-the-case/
      -Aniket
      Forum Rules & Guidelines
    • Peter Noonan
      I do mean cbd file. I am trying to export this model into another analysis software. I am wondering if this file format will maintain split surfaces along with the mesh. My current problem is that surface information is being lost when I try to import my mesh as a different file format.
    • Aniket Chavan
      try giving named selections in Mechanical and then export to CDB...
      -Aniket
    • Peter Noonan
      What am I giving named selections to?
    • Peter Noonan
      I am making some progress creating .cdb. But when importing it to my other software it says that it contains 'no nodal data'. I cannot find any information on the proper procedure to make a named selection online. Do you have advice or is their a tutorial somewhere?
      • Aniket Chavan
        https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_NS_creating.html
        Please check this link for creating named selections. And if you are exporting cdb using cdwrite command as explained in the KM in my first response, you should be able to read that back in Mechanical using the External model.
        -Aniket
    • Peter Noonan
      Update: I have tried to import my .cdb files back into ANSYS and they have no information on the mesh and geometry. AKA I am not exporting my model data to the .cdb file correctly.
Viewing 6 reply threads
  • The topic ‘Export Mesh/Object as CBD’ is closed to new replies.
