February 13, 2024 at 8:16 am
Neil
SubscriberI am wondering how to export materials from ANSYS Workbench to APDL.Â
For now, I am using the ANSYS Workbench for viscoelasticity material and finished the curve fitting and prony series in ANSYS Workbench.
Later, can I export the material data from ANSYS Workbench to APDL .txt file?Â
Thank you for all help. -
February 14, 2024 at 2:20 pm
Chandra Sekaran
Ansys EmployeeOne way is to use the CDWRITE,MAT,filename,ext command. You can add this command along with boundary conditions. Then you can use Solution > write input file to create this file with the material property data in APDL command format
- The topic ‘Export Materials from ANSYS Workbench to APDL’ is closed to new replies.
